A6300 connection to PC
iprior
Hi, can I playback videos from camera to PC using HDMI ?  thanks
1 ACCEPTED SOLUTION
IamNic
Hello @iprior,
unless you use a HDMI-capture device like the "ELGATO Camlink" you can't do that.
The HDMI-port on your PC is an output only.
You can though copy the video-files to your PC and view them there.
- Nic
2 REPLIES 2
Sean_Mc
Moderator
Hi there,
I've been searching the manual and I don't think this is possible to do.  I will try and find out a more definite answer for you.  In the meantime perhaps someone else in the community may be able to help.
Best wishes,
Sean Mc
IamNic
Hello @iprior,
- Nic
