- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
A330 live view not showing full screen
Hi, really hoping someone can help.
I have an A330 DSLR which I've had for some time. Recently someone else was 'having a look' and has hit an option which I have no idea how to clear. I've been through all the options to no avail.
The problem is when using live view, 1/4 of the screen is covered by the bottom info bar (exposure?) and another bar above which is just black and contains no content. This means when taking shots you need to compensate for the lost area of screen as it still appears once that shot is taken. Playback for shots shows it in a reduced size. I thought the most obvious solution was a display option but this does not seem to remove the problem.
I know this is going to be a really stupidly easy solution but I'd be grateful if someone could assist! Photo attached showing the problem:
Mark
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Is the smart teleconverter switched off?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Someone else suggested this on another forum but I don't get it. The smart teleconverter is just a zoom surely? It's always been on since the day it was purchased. All the settings are default and always have been as it's never been used 'professionally'. Can you possibly explain further? Thanks.
