Firmware update Sony A7 III en A7R III
OPGELOST
Instaphoto
Sony A7R III Update
https://www.sony.co.uk/electronics/support/e-mount-body-ilce-7-series/ilce-7rm3
About this download
Benefits and Improvements from the latest update
    Support of "SEL400F28GM"and "SEL24F14GM":
    • Optimization of the optical image stabilization performance, and addition of a new image stabilization mode of the lens (Mode 3)(Only "SEL400F28GM").
    • Addition of a Function Ring(Lens) to the menu.
      Note: For the SEL400F28GM lens, the APS-C S35/Full Frame Sel. setting is assignable to the Function Ring in addition to Power Focus.
    • Addition of [Aperture Drive in AF] setting in the menu.
      *Using the lens "SEL400F28GM" or "SEL24F14GM", when [Silent priority] is selected, the sound emitted by the aperture drive will be reduced. This is useful in shooting conditions where camera.
      noise should be kept to a minimum. Note that Auto Focus may become slower when [Silent priority] is selected.
    New features:
    • [AF Track Sens] can be assigned to a custom key.
    • When used with the LA-EA3 mount adaptor, all focus areas are supported.
      Note : Focus Area options added : Zone, Expand Flexible Spot, and Lock-on AF.
      Bracket shooting is available during silent shooting when [File Format] is set to [RAW] or [RAW & JPEG] and [RAW File Type] is set to [Uncompressed].
    Other improvements:
    • Improvement of the performance and the overall stability of the camera.
    • Better reproduction of the gradation of RAW pictures.
      Note: Imaging Edge softwareneeds to be updated to benefit from the improvement in the RAW processing.
    • When shooting with a flash in an environment with flickering light sources, the stability of the exposure is improved.
    • Improvement of managing continuously shot images as a group.
      Please refer to the HelpGuidefor updated function usage.
Voor meer informatie en de Firmware update zelf voor de Sony A7 III zie onderstaande link
https://www.sony.co.uk/electronics/support/e-mount-body-ilce-7-series/ilce-7m3
1 GEACCEPTEERDE OPLOSSING
Geaccepteerde oplossingen
Sigiphoto
Voor de volledigheid en met dank aan @FOTOGRAFIELAMP kan dit aangevuld worden met
https://www.youtube.com/watch?v=s_EoP28crJA
grt, Sigi
mijn foto's op; 500px en
4 ANTWOORDEN 4
Bibi_Sony
Bedankt voor het delen! :slight_smile:
Instaphoto
New A7III and A7rIII 2.0 firmware causes issues with third party batteries
Zelf geen uitdaging mee. Gebruik aantal originele batterijen.
Sigiphoto
@Instaphoto
Goed dat je dit deelt...maar bedoel je nu uitdaging of probleem?
kan verwarrend zijn voor minder ervaren Sony gebruikers...
grt, Sigi
Sigiphoto
grt, Sigi
