When tap to show lock screen is on,
When the device in off-screen status,it will check the proximity sensor on the top before showing the lock screen.
Once there have something blocking the proximity sensor, it will show a message on center to remind you to prevent any accident operation. However, at that reminder screen, status bar and quick setting menu can be pull down, and item on quick setting menu and notification is operational at that time #xperia1
