Hey,
Since yesterday i am a proud owner of the new Sony Xperia 1 and i like it a lot!
But there are a few problems that needs to be fixed asap.
1. No Netflix Full HD or 4K Support
I've contacted Netflix about this but they say the device is not supported yet.
Even if it has Widevine L1 and a Snapdragon 855. Sony and Netflix needs to fix this.
I want to enjoy this big screen in it's full glory.
2. Brightness to low sometime in house
I know with adaptive brightness, the brightness can be higher in direct sunlight.
But sometimes indoors with bright lights, i need this aswell can we get a vivid color support or manual brightness boost.
3. Brightness-slider to high.
Can you make the brightness slider in the lower end of the notificationtray?
4. Fingerprint scanner doesn't work mostly of the times.
I don't know if it is my sweaty hands but i got problems with the fingerprint scanner.
Will try to register my finger again multiple times as seperate fingers.
5. Touchsense to be more sensitive
On all of my devices i use a case but because of this touchsense can't be pull off.
Can you make it more sensitive horizontal instead of vertical? Maybe register on screen?
6. Switching between lensen without blacking out screen.
Switching between the 3 camera lenses could be easier with 1 bigger button the choose between the 3 and not tap multiple times. Also blacking out the screen doesn't need to be if you look at other companies, look at what huawei, samsung or oneplus does with that and update it.
7. Seperate HDR button.
I want to be able to turn the HDR on or off in auto mode.
Can you fix this?
8. Fullscreen mode in browser video's and apps.
In some apps and in the chrome browser i can't always zoom it to fit to full screen.
If it's possible make a fullscreen button in gamecentre or zoom in pinch like youtube.
9. Android Q beta support
As last i would like to participate in Android Q beta but it's not supported yet.
Thanks for making such a great device if you fix most of the things above, i know i will enjoy it alot more! This is maybe the best device i've ever owned. (and i owned a lot of smartphones!)
